paolo bevilacqua Mon, 02/09/2009 - 11:23
  • Hall of Fame,
    Founding Member
Give the designated router an higher priority in each respective configuration.
divyapratap.singh Mon, 02/09/2009 - 12:31
I get your point, let me ellabroate my requirement in bit detail:
Suppose if the HSRP active changes due to some reason, at that time how should i syncronize my PIM-DR.
paolo bevilacqua Mon, 02/09/2009 - 13:33
  • Hall of Fame,
    Founding Member
There is no "easy way". You can either do not be concerned, or build an EEM script to detect the change and reconfigure PIM.
divyapratap.singh Mon, 02/09/2009 - 14:25
Let me try working with EEM script, will get back to you in case of any issues. Thanks for your guidance.
