VPN termination errors
Feb 9th, 2009
Hopefully someone can help with a termination issue I'm having with a PIX-515e firewall; software version 6.3.4, pdm version 3.0.2.
We're getting constant vpn termination errors (reason 412 and 413) from a group of users at one location. I am by no means a pix guru, but I've verified that nat-t is configured. I can't figure out how to determine if there is a group policy set. I'd be happy to post or email the current config if that will help - it's about 150 lines long.
Ivan Martinon Mon, 02/09/2009 - 14:24
  • Cisco Employee,
Go ahead and post it, we need to see if you are missing some lines there
Ivan Martinon Tue, 02/10/2009 - 13:32
  • Cisco Employee,
Well it all looks good on your config, can you turn on the following debugs?
debug crypto isakmp
debug crypto ipsec
eriklozano Thu, 02/12/2009 - 10:03
Using the CLI, I entered the two commands you listed. But, I'm not sure what to do next.
Ivan Martinon Thu, 02/12/2009 - 10:04
  • Cisco Employee,
You need to get a vpn client to try to connect to your pix to generate debug logs
eriklozano Wed, 03/04/2009 - 05:53
Now that the debug logs have been enabled for several weeks, where do I find the log files?
Ivan Martinon Wed, 03/04/2009 - 06:56
  • Cisco Employee,
If you did not set any syslog servers, you need to get the output of the show log, however this log is a circular buffer most likely some events have been overwritten.
eriklozano Wed, 03/04/2009 - 09:07
And how exactly do I get the output of the show log?
