site's slowness
Overall Rating: 5 (1 ratings)
Joseph W. Doherty Mon, 02/09/2009 - 16:50
If the other computer applications also are depending on network communications, and the network is congested, especially if there's no QoS, then all those applications will often slow or have problems too. Applications using just local computer resouces usually aren't impacted.
Joe:
Thanks! But what i dont quite understand is why applicatoins like Outlook, IE, freeze and making you can't do anything else but wait? My understanding would be that the applications that depend on network can freeze but others, such word when you are not opening the network file, should freeze.
Is there settings that i can take care of?
thanks,
Han
Joseph W. Doherty Mon, 02/09/2009 - 19:57
Does your Outlook communicate with a mail server that's on the network? Does it auto poll for new inbox mail? Address book updates?
With IE, nothing on a page is coming via the network?
I wouldn't expect something like Word to have a problem openning a local disk file, but that's also assuming all the application components are also local, user profile storage is local, etc.
Perhaps background security verification, even opening a local disk file, is hitting AD across the network.
For a quick test, you might try, disconnecting host from the network and see how applications work.
