Allow *.ppt but block *.pps
Feb 9th, 2009
i will allow MS Powerpoint *.ppt files but will block *.pps files. With the Mime-Type application/powerpoint or application/vnd.ms-powerpoint all Powerpoint-Files will be blocked.
How can i do this ? Is there any way to define a file-extension to be blocked ?
Jens
jowolfer Tue, 02/10/2009 - 17:06
Jens,
The only way to block a file extension is to use a custom category and define a regex value.
For your example, you could use:
\.ppt$
...to allow ppt files. Custom URL categories take prescedence over file type blocking.
