ASA: Active/Stdby: Stateful Failover: IOS upgrade query
Feb 9th, 2009
  • Gold, 750 points or more
Hi All,
I have 2ASAs in Active/standby with stateful failover mode. Planning to upgrade IOS. Wanted to disconnect Standby from network first and upgrade the IOS. Now, the inside interface config..
interface GigabitEthernet1/0
nameif inside
security-level 100
ip address 192.168.20.6 255.255.255.192 standby 192.168.20.7
When the standby unit is disconnected and connect the laptop directly with Xover cable, if I assign my laptop with any ip in the inside interface subnet range, will it work or due to standby ip config, any issue will be there..?
TIA
MS
apdatasoft Mon, 02/09/2009 - 23:21
there shouldn't be any issue. I did the same.
AP
mvsheik123 Tue, 02/10/2009 - 08:14
Thank you for the reply. It worked.
MS
