WCS Serial Number - Where can I find it?
Feb 9th, 2009
Hi There,
We are running WCS 4.2 on linux. I need to find the serial number of the software so I can raise a TAC case. Does anyone know how to find the serial number? I cant see it via the GUI.
Overall Rating: 5 (2 ratings)
serotonin888 Tue, 02/10/2009 - 00:10
I'm afraid on my system it only gives the following
Version
Type
Number of licensed AP's
But it does not give me the serial number of the software..
tarv1s1umacelum Mon, 07/20/2009 - 23:43
Hi Serotonin,
have you finally found the serial number of your WCS?
I've the same problem with a Windows version.
Thank you
Lucien Avramov Tue, 07/21/2009 - 17:15
There is no serial number as Cisco does not provide you with the server. You have a part number WCS-STANDARD-K9 for example and a license.
serotonin888 Tue, 08/04/2009 - 11:38
In the end I raised a TAC and used the "call cisco" option. They had to run through the Smartnet contracts and then created a ticket. So no serial number for the prioduct. You just have to speak to Cisco to riase a TAC case.
Lucien Avramov Tue, 08/04/2009 - 11:59
That is what I mentioned earlier as I am in TAC :-)
No serial number for WCS, it's a software, with a software license, there is no hardware involved for serial number.
Please mark this resolved if it's the case.
r.stockton Wed, 09/07/2011 - 13:30
For anyone that searches for this same answer - you would go Help/About and grab your Host Name information (since there is no serial number) and plug this into the Serial Number field when opening an SR with Cisco.
No need to call TAC.
-Robert
Thomas Jennings Fri, 06/15/2012 - 12:58
All:
It is corect that WCS has no Serial Number but for refernce to open a TAC case you generally need the PAK  (Product Auth Key) which is sent when the product is purchased. Other then that the Hostname is next best.
Scott Fella Fri, 06/15/2012 - 13:32
You are correct. The license and pak files can be accessed in the WCS license area.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
