Error in MFC V1.4
Feb 9th, 2009
I use Ironports Mail Flow Center V.1.4.0, but have trouble with some reports:
An error has occured:
The following report(s) failed during their scheduled run time:
'Volume Report by Domain - weekly' - Due to error: _mysql_exceptions.InternalError - (3, "Error writing file 'D:\\Application_Logs\\Mail Flow Central\\db\\Data\\tmp\\MY62' (Errcode: 28)")
Database size:
Using 41.03 GB of 50 GB (82.07 % full)
We store the data for 1 month and there is enough free space on the disk available.
What can I do ?
kluu_ironport Thu, 02/12/2009 - 09:25
Mysql uses the temp directory when creating temp tables. Some reports (particularly the volume by user report) can consume a very large amount of this temp space (eg: 30 gig database uses as much as 6 gigs).
The solution is to:
1. Create more space on your c: drive.
2. Modify c:\my.cnf file to use an alternative location for temp space.
[make a backup of the c:\my.cnf prior to make edits to it]
Under the [mysqld] section add the following line
set-variable = tmpdir=E:/mysqltemp
Good luck.
Andreas Krueger Thu, 02/12/2009 - 12:37
Thank you very much, this could be the problem.
On C: are onle 6 GB space available.
