No Messages from Syslog Server
Feb 9th, 2009
We have ASA 5550 (ver. 8.0.4). We configured the ASA so that messages can be sent to Syslog server. We were able to ping the Syslog server from the ASA. However, no messages are sent to the Syslog server. The Syslog server has been configured to accept messages from the ASA. Below is part of the config of the ASA. Thanks.
logging enable
logging list Events level errors class auth
logging list Events level errors class session
logging list Events level errors class sys
logging console errors
logging asdm informational
logging mail errors
logging from-address <A HREF="mailto:[email protected]">[email protected]</A>
logging recipient-address <A HREF="mailto:[email protected]">[email protected]</A> level errors
logging host Inside XXX.X.X.XXX
Overall Rating: 5 (2 ratings)
eddie.mitchell@... Tue, 02/10/2009 - 10:59
I don't see the configuration line to define your logging trap. You should have a line like this:
logging trap (I have mine set to informational)
I would also recommend enabling timestamps on your syslog messages via:
logging timestamp
Hope this helps.
dianewalker Tue, 02/10/2009 - 12:50
I added "logging trap informational" and "logging timestamp" statements on the ASA. Still, nothing showed up in the Syslog server. Do you have any other suggestions? Thanks.
dianewalker Tue, 02/10/2009 - 13:35
Eddie,
Please ignore my previous message. I added "logging facility 19" and now I started to receive messages from the Syslog server. May I ask you another question? Do I open the Sylog file by using Excel? I just wonder if you would use other utility to open the Syslog file. Thanks again.
dianewalker Tue, 02/10/2009 - 18:42
Thanks for your prompt response and information, Eddie. My Syslog server is not a Kiwi server. I am using the logs to troubleshoot problems and to see the activities on the ASA. I will continue using Excel to open the Log files. Thanks very much again.
eddie.mitchell@... Wed, 02/11/2009 - 05:01
If it's a Unix based syslog server, you can just use the standard commands to view and search through the syslog files.
cat
cat | grep
tail
tail -f
