FTP problem with ACS generating self-signed certificate
Feb 9th, 2009
I have ACS 4.2 SE in my network, I want to enable PEAP authentication method, so I must generate a certificate on the ACS appliance.
I followed the steps of generating Self-Signed certifcate, it prompted me two fields one for the certificate parameters and the other for ftp connection.
I used Program Name: Cerberus FTP Server Version:2.31 a free software to make my laptop as a ftp server.
First I tested the connection from other computer and it worked fine with the username and password which I defined on the FTP application.
But when I tried to upload the certificate on the ftp server an error appears on the ACS stating
"Check that the username and passowrd are correct"
I am sure that I wrote the username/pass correct on the ACS and I have already test it before from other computer.
So could anyone help ?
Thanks...
Kareem Ismail
Yudong Wu Tue, 02/10/2009 - 12:14
You can do a sniffer on you laptop to see what username/password is sent by ACS. And compare it with your testing PC.
I am not sure if it is related to domain name.
