SSL VPN (WebVPN) on 7206VXR - IOS Based
Feb 9th, 2009
I am having trouble setting up IOS based SSL VPN ( WebVPN ) on Cisco 7206VXR. The IOS I am using is c7200-advipservicesk9-mz.124-22.T.bin (Tried c7200-advsecurityk9-mz.124-20.T2.bin as well) but couldn't get the Tunnel mode working. I used the following documents as a guideline:
<A HREF="javascript:newWin('http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6586/ps6657/prod_white_paper0900aecd8051ac50.html')">http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6586/ps6657/prod_white_paper0900aecd8051ac50.html</A>
The SSL VPN connects fine without any problem, but it just gets stuck when I want to go to the tunnel mode. Once I click the tunnel button, a pop up window appears saying downloading necessary packages, and that's it. It just stays there forever. I checked the installed package and they look fine. The client package I am using is sslclient-win-1.1.4.179-anyconnect.pkg.
It comes up with the following error in the router log:
<!!> %SSLVPN-5-SSL_TLS_ERROR: vw_ctx: UNKNOWN vw_gw: SSL_GW i_vrf: 0 f_vrf: 0 status: SSL/TLS connection error with remote at <!!>
Any suggestion?
Thanks in advance.
