Load balancing for 2 CME
Feb 9th, 2009
I have 2 x 2851 cme router forming a HA reducdant. For this condition, how can I config the routers to support load balancing for 2 x E1 ?
Please find the attached drawing for your information.
Leung Che Man
Overall Rating: 3 (1 ratings)
Paolo Bevilacqua Tue, 02/10/2009 - 01:53
The failure rate of cisco router is extremely small, if you want to keep a secondary CME that's ok, but the easier way is that in case of failure you move circuits from one box to another. Having the PRI connected to two different boxes involves more configuration. However it can be done a pots and voip DP. If you do not have experience in configuring voip I recommend you hire a professional to save you time and frustration.
