How to Resolve Native Vlan Mismatch?
Answered Question
Feb 9th, 2009
Access switch (3550) is connected to Distribution switch (4506). I DO NOT want the access switch to have a trunk connection into the Distribution switch since only users in Vlan 3 will be on the access switch. Here's my configuration on the
access switch:
Interface Fa0/24
Description Uplink to Distro
switchport
speed 100
duplex full
Here's the configuration on the distribution switch:
Interface Fa0/1
Description Uplink to Access
switchport
switch access vlan 9
speed 100
duplex full
How can I resolve the native Vlan mismatch in my log? If I put all ports on the access switch into Vlan 3 do I have to enable trunking since it's passing both Vlan 1 and 3? Thanks in advance.
Correct Answer by justbailey about 8 years 1 week ago
David,
Put the access and distribution switchport into "switchport access vlan 3" as Glen suggests. This will eliminate any confusion with vlan 1 and your error messages will go away.
Correct Answer by glen.grant about 8 years 1 week ago
You say vlan 3 I assume you mean vlan 9 . The only way to fix it is make sure both sides are in vlan 9 , the dist. switch interface says vlan 9. Instead of having all the access ports in vlan 1 you will have to create the layer 2 vlan 9 on the 3550 then put all your ports into vlan 9 , this will get rid of the message . If your 3550 management address is in vlan 1 now then you have to change your SVI to vlan 9 also instead of vlan 1 .
3550
conf t
vlan 9
interface range f0/1 - 24
switchport access vlan 9
int vlan 9
ip address
Overall Rating: 5 (2 ratings)
Leo Laohoo Mon, 02/09/2009 - 17:34
How about you remove the native VLAN statement or you can disable the error message from the interface where it's coming from?
int
no logging event trunk-status
davidhuynh5 Mon, 02/09/2009 - 17:49
Yes, I have done that. Also, I can disable cdp which will prevent the message from showing up in my log. However, I want to fix the problem, not hide it.
If I understand correctly when I get that msg, my user vlan 3 information is bleeding over to the native vlan.
Correct Answer
glen.grant Mon, 02/09/2009 - 18:19
3550
conf t
vlan 9
int vlan 9
ip address
davidhuynh5 Mon, 02/09/2009 - 18:51
Sorry, I meant vlan 3. With your suggestion I can still keep the connect as an "access" connection even though its passing Vlan 1 and Vlan 9?
babatunde_sanda Mon, 02/09/2009 - 19:42
My Friend,
Native vlan mismatch will always occur because these two switches are acting independently but yet connected. From your explanation this Vlan 3 is still part of your network. For traffic for that VLAN to be carried, the connecting ports must be in trunk mode. VLAN 1 which is the native VLAN by default will always be carried. Now for you to know where the native vlan mismatch is; go to both switches. Professionally I say your distribution switch will have the superior configurations.
Do a “show interface (interface number) switchport” on both switches.
Access switch
Sho Interface Fa0/24 switchport
Distribution switch
Sho Interface Fa0/1 switchport
From your output look for what the switch is reporting as the native vlan (You can do this on the interfaces connecting both switches. If you already know what your native vlan is then skip all this steps.
For you to specify the native vlan, connecting ports have to be in trunk mode.
Access Switch
Interface Fa0/24
Switchport mode trunk
Switchport trunk native vlan (your discovered native vlan number)
This configuration will only be needed on your access switch. Make sure your access switch revision number is lower than the distribution switch before you make this change if they are in the same vtp domain (If you don't you can wipe out your entire vlan on your network).
Correct Answer
justbailey Tue, 02/10/2009 - 08:23
David,
kunalthakkar Tue, 02/10/2009 - 05:17
I agree with babatunde_sanda's recommendation. One more thing I infer from your post is that you want to avoid configuring trunk between the Access and Distribution layer switches because the Access Layer switch will only use one VLAN (vlan 3). Well, you can use the 'allowed vlan' command to specify which VLANs you want to allow thru the trunks.
For example you can do following on the access switch:
switchport trunk native vlan 3
switchport trunk allowed vlan 1,3
[assuming the disto switch has vlan 3 as its native vlan for the corresponding port]
