add 91 for incoming call
Feb 9th, 2009
Hi All,
I am using CUCM. in order to add 91 prefix for incoming call from PSTN in H.323, we add translation rule and profile in gateway under voice port configuration. If I use MGCP and apply translation rule and profile under voice port configuration in gateway, does it add 91 prefix for incoming call from PSTN?
or I have to add 91 prefix for incoming call from PSTN in CUCM configuration rather than gateway?
any suggestion would be very appreciated.
Alex
gogasca Mon, 02/09/2009 - 23:41
  • Green, 3000 points or more
In MGCP you do it in CUCM. We have a service Parameter or you either configure a Translation pattern and modify calling number (Prefix)
Rob Huffman Tue, 02/10/2009 - 05:33
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Alex,
Just to add a note to the great ideas from Gonz, there is a good "step by step" guide here;
Add Prefix to the Missed Call Number
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00805b6f33.shtml
Hope this helps!
Rob
alex goshtaei Tue, 02/10/2009 - 09:08
thanks for your info. But I saw "prefix DN" under digital PRI port configuration page, if I add 91 in prefix DN, is it going to add 91 for all incoming call for that port? I'm using CUCM 7.0.
Alex
kelvin.blair Tue, 02/10/2009 - 09:16
  • Silver, 250 points or more
That is correct. All numbers will be prefixed with 91 when they arrive in CM. You will have to do route patterns for local calling to strip the 91 off and send as a local call when returning the calls..
alex goshtaei Tue, 02/10/2009 - 09:19
thanks for your reply, actually our service provider sends 10 digits no matter it is long distance or local. so always 91 is applicable
thanks
Alex
