gogasca Mon, 02/09/2009 - 23:42
Which IP Phone model?
If you use Search function in CCO or this forum you will find a few examples.
Jaime Valencia Tue, 02/10/2009 - 04:03
you can also search NetPro, there are hundreds of guys that have asked this before so you'll get the answer just by searching 5 minutes here
java
if this helps, please rate
