how to enable the management port in Cat4k Sup 4
Feb 10th, 2009
anyone know how to enable the management port in Sup 4 ? for example in Cat6 we just type in the 5/1 - media type rj45.
how about this cat4 sup 4 ?
any idea ?
Overall Rating: 3 (3 ratings)
ney25 Tue, 02/10/2009 - 00:51
Hi bro,
thanks for your information.
but, i got some info from cisco web.
Configuring the Ethernet Management Port
To specify the Ethernet management port in the CLI, enter fastethernet1.
To disable the port, use the shutdown interface configuration command. To enable the port, use the no shutdown interface configuration command.
To find out the link status to the PC, you can monitor the LED for the Ethernet management port. The LED is green (on) when the link is active, and the LED is off when the link is down. The LED is amber when there is a POST failure.
To display the link status, use the show interfaces fastethernet 1 privileged EXEC command.
isn't it the way ?
btw, are you from ibm ?
if yes, mind to give me your email coz, i am from ibm as well :P
mahmoodmkl Tue, 02/10/2009 - 03:39
The management port u r refering is it on the SUP or one of line cards..please confrim.
As the management port on the sup will not will operational under normal operation of the switch it will be available in rommon mode only.
ney25 Tue, 02/10/2009 - 03:49
Hi ,
yes, i am talking about the port in the SUP engine.
any idea how to use this port ?
