Deleted all Files in Flash.
Answered Question
Feb 10th, 2009
I did something really stupid. I deleted all the files in flash and now when the switch boot up, it cannot find the IOS to load and gives the "switch :" prompt. I was trying to boot it into ROMMON mode and copying the ios which I have downloaded over the console cable
Any ideas on the best way to get the IOS back on this switch quick smart.
Thanks a million
Anthony.
Correct Answer by peterlmyers about 8 years 3 months ago
Hi Anthony,
If you are sure you have copied a new IOS over to the flash it's possible there's an old "boot system" command left in the config that is telling the switch to boot the old image file - presumably non-existant now.
If this is the case you should be able to do the following from switch: mode -
flash_init
load_helper
dir flash:
boot flash:FILE_NAME
If this boots be sure to modify the "boot system" line in the config.
Otherwise you will need to copy a new IOS over, in which case there's a guide for the 3750 at http://www.cisco.com/en/US/products/hw/switches/ps628/products_tech_note09186a0080169696.shtml
Hope this helps
Cheers
Overall Rating: 5 (1 ratings)
Correct Answer
peterlmyers Tue, 02/10/2009 - 02:24
Hi Anthony,
flash_init
load_helper
dir flash:
Hope this helps
Cheers
Anthony O'Reilly Tue, 02/10/2009 - 03:03
Hi Peter,
I haven't even got that far yet. I am looking for advise on how to copy the ios image from my pc to the switch (which has no ios in flash) via the console cable.
Anthony.
adamclarkuk_2 Tue, 02/10/2009 - 03:12
  • Silver, 250 points or more
Hi Anthony
He has answered your question, if you read the link it will explain how to use xmodem to copy the IOS over.
