rajett Tue, 02/10/2009 - 08:42
Hi Aleksey,
I cannot view the attachement. I get a "Document does not exist!" message. I informed the NetPro staff to see if we can get that fixed as it has affected more than one post.
If this is a "drop rule" then go to Rules > Drop Rules and find the rule you wish to remove.
Click the box next to the rule and click "change status" to change it to inactive.
If you are running 6.0.1 or later you can click the box next to the rule then click "Delete" to delete the rule.
In versions <6.0.1 you cannot delete a drop rule.
rajett Tue, 02/10/2009 - 14:39
I notified the NetPro staff and they are working on the attachment issues.
a.alekseev Thu, 02/12/2009 - 15:06
Thanks, rajett
I can delete drop rules.
But how can I delete false positives?
