CICP compatible with Belkins and Netgear
Feb 10th, 2009
I have 3 customers that have a combination of Belkin and Netgear wireless routers. They can connect VPN and CICP phone register without problems however when they use wireless the soft phone does not register.
If I take it home and use my Linksys works fine.
What can be the problem and how do I fix it?
Thanks.
paolo bevilacqua Tue, 02/10/2009 - 04:08
  • Hall of Fame,
    Founding Member
Check preferences->network, set device name to be same as in wired connection.
paolo bevilacqua Tue, 02/10/2009 - 10:03
  • Hall of Fame,
    Founding Member
From the PC with IPCP, can you ping CM in first place ?
