aggregate label problem
Answered Question
Feb 10th, 2009
  • Silver, 250 points or more
on 12.4 11 T4 if i run the command for directly connected interface I got the aggregate label for that vrf. But if the ios is changed to 12.2 31 SB13 then I am getting no label. Which type of problem is it?
regards
shivlu jain
Correct Answer by Harold Ritter about 8 years 4 months ago
Shivlu,
What you are referring to is the difference between "Aggregate", which forces an IP look-up and "Untagged", which forwards the packet directly towards the CE without an additional look-up.
In the following example, 192.168.27.0/24 is the Ethernet link between the PE and CE and it is therefore an aggregate and requires further processing before forwarding. On the other hand, 7.7.7.7/32 is received from the CE and packets destined to it are forwarded to the CE without any further look-up.
12.4(14)T
r2#sh mpls for
Local Outgoing Prefix Bytes tag Outgoing Next Hop
tag tag or VC or Tunnel Id switched interface
26 Untagged 7.7.7.7/32[V] 0 Et0/0 192.168.27.7
28 Aggregate 192.168.27.0/24[V] \
As you can see below, both these cases will show as "No Label" in the outgoing label field in the new mode (MFI).
12.3(31)SB13
r2#sh mpls for
Local Outgoing Prefix Bytes Label Outgoing Next Hop
Label Label or VC or Tunnel Id Switched interface
25 No Label 192.168.27.0/24[V] \
0 aggregate/red
28 No Label 7.7.7.7/32[V] 0 Et0/0 192.168.27.7
r2#
The fact that 192.168.27.0/24 needs an additional look-up is indicated by the "aggregate/" in the outgoing interface field rather than in the outgoing label field as it was the case before MFI.
Overall Rating: 5 (2 ratings)
Harold Ritter Tue, 02/10/2009 - 06:18
  • Cisco Employee,
Shivlu,
This is not a problem. This behavior change was introduced in IOS via the new MPLS Forwarding Infrastructure (MFI). MFI was introduced to the 12.4T train in 12.4(20)T, hence you are seeing the old behavior in 12.4(11)T4. 12.2(31)SB13, on the other hand, has the MFI code.
If you examine the new behavior compared to the old, it make sense that the outgoing label show as "no label" as the traffic flowing towards the CE is unlabeled.
shivlu jain Tue, 02/10/2009 - 07:35
hi hritter
"Aggregate" and "No Label" having different functionality. Like aggregate means need to do the ip lookup and no labels means no need to do the ip lookup.
regards
shivlu jain
shivlu jain Tue, 02/10/2009 - 07:45
hritter
kindly provide any links for the same from where I can understand about MFI.
regards
shivlu jain
Correct Answer
Harold Ritter Tue, 02/10/2009 - 08:59
  • Cisco Employee,
Shivlu,
12.4(14)T
r2#sh mpls for
12.3(31)SB13
r2#sh mpls for
0 aggregate/red
r2#
shivlu jain Tue, 02/10/2009 - 09:13
hritter
thanks for such the awesome explanation. If possible try to provide some link from where I can get more information about MFI.
regards
shivlu jain
