Problem with FXO script CUE
Feb 10th, 2009
Hello, I have a problem when forming a port FXO that aims at script in the CUE. It leaves the menu correctly but when beating the wished option the CUE does not realize. I imagine that it is a problem with the signaling but not that changes I must realise.
Paolo Bevilacqua Tue, 02/10/2009 - 04:34
Of what you wrote (or translated automatically), very little can be understood.
However, have you configured "dtmf-relay sip-notify" under the DP for CUE ?
sruizpla Tue, 02/10/2009 - 05:12
Hello, thanks to answer and sorry for my auto translate.
I have configured a port FXO that forwards the call to script of module CUE with menus (Press 1 for contact with Administration, press 2 for ....) The call enters correctly, but the system does not recognize the pulsations of my keyboard, I suppose that it is a problem with the signaling.
I have next configuration in my gateway of the dial peer and voice port :
dial-peer voice 2 voip
description Local AIM Auto Attendant
destination-pattern 1921
session protocol sipv2
session target ipv4:
codec g711ulaw
no vad
voice-port 0/0/3
no echo-cancel enable
cptone ES
timing hookflash-out 500
connection plar opx 1921
impedance complex2
Also I have a line ISDN and it works fine, the problem this in port FXO.
Thank you.
