Jaime Valencia Tue, 02/10/2009 - 05:00
  • Cisco Employee,
  • Hall of Fame,
    2011
there are no skins for IPC, IPC is a program to emulate a the functionality of a 7970 on a PC. it was not created thinking of the looks
java
if this helps, please rate
Rob Huffman Tue, 02/10/2009 - 05:31
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Mattieu,
Just to add a note to the good info from Java, I just thought you might be interested in using the "Compact" skin;
Skins Allows you to change the look of the interface. Cisco IP Communicator
comes with two skins: the default skin (right-click > Skins > Default
Mode) and the compact skin (right-click > Skins > Compact Mode).
http://www.cisco.com/en/US/docs/voice_ip_comm/cipc/2_1/english/user/guide/cug21book.pdf
Hope this helps!
Rob
matthieuh Tue, 02/10/2009 - 05:48
Thanks a lot but i wanted to know if we could change entirely the skin (transparency, different colour etc ...)
Thanks for your answer
Rob Huffman Tue, 02/10/2009 - 06:01
  • Hall of Fame,
    Founding Member
Hi Mattieu,
You are most welcome :) It was worth a try.
Cheers!
Rob
ionmihalache Wed, 06/24/2009 - 05:14
Hi Rob,
in the folder C:/Programs/Cisco Systems\Cisco IP Communicator\skins\images
you have all the skin images
and then you must edit the XML configuration file too in the folder:
for example you will find:
"default.xml" and "mercurio.xml"
thuerlimann1 Tue, 10/07/2014 - 02:30
Hi, are there any updates on this? Because the default GUI looks really "ugly" and old fashioned like previous mentioned..
