BR-1310 in Bridge Mode Help !!
Feb 10th, 2009
I have some problem with a bridge configuration ... on other site this config is well but ... sometime it not works ..
version 12.3
no service pad
service password-encryption
hostname client-externat
enable secret administrat0r
ip subnet-zero
no aaa new-model
dot11 ssid BRIDge2
authentication open
guest-mode
username Administrateur password administrat0r
bridge irb
interface Dot11Radio0
no shut
no ip address
no ip route-cache
encryption key 1 size 128bit 7 9230222917362715E228560C7F5E transmit-key
encryption mode ciphers ckip-cmic
ssid BRIDge2
speed basic-6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role non-root
rts threshold 2312
no cdp enable
bridge-group 1
interface FastEthernet0
no shut
no ip address
no ip route-cache
bridge-group 1
bridge-group 1 path-cost 40
bridge-group 1 spanning-disabled
hold-queue 80 in
interface BVI1
no shut
ip address 192.168.230.8 255.255.255.0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
control-plane
bridge 1 priority 10000
bridge 1 protocol ieee
bridge 1 route ip
hostname root-hangar
enable secret
enable password
ip subnet-zero
no aaa new-model
dot11 ssid BRIDge2
authentication open
bridge irb
no shut
no ip address
no ip route-cache
ssid BRIDge2
station-role root
rts threshold 2312
no cdp enable
infrastructure-client
bridge-group 1
no shut
no ip address
no ip route-cache
bridge-group 1
hold-queue 80 in
interface BVI1
ip address 192.168.230.7 255.255.255.0
no ip route-cache
ip http server
control-plane
bridge 1 priority 9000
bridge 1 route ip
line con 0
exec-timeout 0 0
line vty 0 4
password cisco
login
line vty 5 15
password cisco
login
end
root-hangar#sh run
Building configuration...
Current configuration : 1299 bytes
version 12.4
no service pad
enable secret 5
enable password
no aaa new-model
resource policy
ip subnet-zero
dot11 ssid BRIDge2
authentication open
bridge irb
no ip address
no ip route-cache
ssid BRIDge2
station-role root
rts threshold 2312
no cdp enable
bridge-group 1
no ip address
no ip route-cache
bridge-group 1
hold-queue 80 in
interface BVI1
no ip route-cache
ip http server
bridge 1 route ip
jeff.kish Tue, 02/10/2009 - 14:03
  • Silver, 250 points or more
What exactly is the problem? Is the connection dropping?
How far apart are these bridges? Are they using internal or external antennas?
To troubleshoot, try placing the bridges into install-mode (configured under dot11Radio0 -> station-role) on all bridges, and ensure that the signal strength is above -67dBm. The higher above this marker, the better. If it's below -67dBm, it might be a signal issue that can be resolve with a larger antenna.
If the distance is large, you should include the "distance" command under the dot11Radio0 interface, and it should be expressed in kilometers. This is very important if your link is over a kilometer.
I hope some of this helps!
Jeff
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
