iflastchange reset.
aryanadonis
Issue is that when the sysUpTime MIB value rolls around to zero after 496
days and the values of iflastchange don't. This gives us dates in the future when polling with SolarWinds Port Mapper to determine the date of last status change on a port. Can the iflastchang MIB value be cleared with a command? The only way I currently know how to correct the values is reboot the switch.
David Stanford
ifLastChange cannot be reset with any command. The only way to clear any snmp counter/time tick is to reload.
David Stanford
Thanks davistan.
