SIP packet size
Answered Question
Feb 10th, 2009
we have seen that CISCO gateways add "proprietary" SIP heade fields such as:
- Cisco-Guid
- Timestamp
Is there a way to disable them to be written in SIP packets?
Correct Answer by Nicholas Matthews about 8 years 2 months ago
You can take a look at this document:
http://www.cisco.com/en/US/products/sw/voicesw/ps5640/products_configuration_example09186a0080982499.shtml
You should be on 12.4(20)T or later to try these features. It says this is a CUBE feature, but I've confirmed it on one of my CME boxes in the labs.
This feature allows for you to do SIP header modifications for outgoing SIP messages. This will allow you to remove headers as long as they are non-mandatory.
hth,
nick
Overall Rating: 5 (1 ratings)
Correct Answer
Nicholas Matthews Tue, 02/10/2009 - 06:51
  • Red, 2250 points or more
hth,
nick
