3511 MCU not booting
Feb 10th, 2009
I have a 3511 MCU in my lab which will not boot. I suspect it may be a hardware problem but I don't have much experience with this device.
Here's what I get when it boots:
CPU : MPC755
VxWorks Version : 5.5
BSP version : 1.86.1D
Created : Aug 15 2004, 17:59:05
WDB : Not included
-> Boot line: motfcc(0,0)rvhost: e=10.2.30.99:FFFFFF00 g=10.2.30.254 o=±
ViaIP MPC755_MPC8260.
BSP version VER_2_0_1REV 1.0
Memory Size: 128 MBytes.
HW Version:0x3
bspSetRoutingTable: Error in routeAdd.
BSP_EXC: Exception hook added
calling Pre Startup ...
MEMORY OK (address: 0x0 - 0x3000)
calling Main Application ...
The last MCU config burn operation wrong: WARNING
Retrieved old volume params with %75 confidence:
Volume Parameters: FAT type: FAT16, sectors per cluster 255
255 FAT copies, 0 clusters, 65535 sectors per FAT
Sectors reserved -1, hidden -1, FAT sectors 16711425
Root dir entries -1, sysId (null) , serial number ffffffff
Label:" " ...
Disk with 512 sectors of 512 bytes will be formatted with:
Volume Parameters: FAT type: FAT12, sectors per cluster 1
2 FAT copies, 500 clusters, 2 sectors per FAT
Sectors reserved 1, hidden 0, FAT sectors 4
Root dir entries 112, sysId VXDOS12 , serial number ffffffff
Label:" " ...
************* LOGGER VERSION: 1.21 *************
Initializing RVLogger System...
VxWorks (for ViaIP MPC755_MPC8260) version 5.5.
Kernel: WIND version 2.6.
Made on Aug 15 2004, 17:59:05.
Boot line:
