How to debug on ACE/ACE4700?
Feb 10th, 2009
I try debug ssl on ACE, but no output is displayed. output is displayed/mixed after 'sh run' command. It's a bug, or 'feature'?
here is config:
logging enable
logging fastpath
logging timestamp
logging trap 7
logging buffered 2
logging queue 100
logging host 10.2.255.249 udp/514
debug ssl is enabled
and no debug info is displayed till any command which generate text output to console:
# sh run
Generating configuration....
2009 Jan 30 13:34:08.510490 ssl mgr: (ctx:1)Generating ascii config for
context 1
2009 Jan 30 13:34:08.510529 ssl mgr: (ctx:1)acfg_cfg_msg_type is
ACFG_CFG_TYPE_RUNNING
2009 Jan 30 13:34:08.510562 ssl mgr:
(ctx:1)ssl_process_chaingroup_acfg(): ENTER
2009 Jan 30 13:34:08.510600 ssl mgr: (ctx:1)Found chaingrp CERT_CHAIN in
ctxt
logging enable
logging fastpath
logging timestamp
logging trap 7
logging buffered 2
logging queue 100
<cut>
