Cisco AP 1131
Feb 10th, 2009
I have two Cisoc AP 1131's. One is upstairs and the other is downstairs. I am getting complaints from users that they are getting dropped from the wireless network and sometimes a user upstairs may connect to the WAP downstairs. Is there a way to control which WAP a user connects to? My company will not allow me to purchase Wireless LAN Controllers. Thanks for any help.
mark.cronin Tue, 02/10/2009 - 07:46
Have you done a site survey?
Can you check that your APs are on different channels ie
Upstairs channel 1
Downstairs channel 11
Also can you check for other APs in the area by using Netstumbler or Vistumbler
You should try to avoid the channels that these APs are using
Mark
gbarden Tue, 02/10/2009 - 08:52
Yes, they are on different channels, chanel 4 and 9. However they are not hard coded to the channels. Should I manually set them?
jeff.kish Tue, 02/10/2009 - 13:50
  • Silver, 250 points or more
You should always try to hard-set them for 1, 6, or 11. The reason is that these are the only three channels that do not overlap with each other. 4 and 9 overlap very slightly.
You can do MAC-based authentication if you'd like to go that far. The problem with that is if one AP goes down, your hosts on that AP won't be able to attach to the other one. Still, it's easy enough to disable, and it might be good to do for testing purposes.
To do a simple MAC blacklist, issue the following commands in config mode:
access-list 700 deny xxxx.xxxx.xxxx 0000.0000.0000
(repeat as needed)
access-list 700 permit 0000.0000.0000 ffff.ffff.ffff
dot11 association mac-list 700
That will block all MAC addresses you want to blacklist from a particular AP. If you want to disable to blacklist, simply input:
no dot11 association mac-list 700
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
