AA when done repeating several times send to ext
Feb 10th, 2009
Trying to have to AA not play the goodbye prompt but send to a direct ext if end user does not hit menu options.  Also, helps out if a rotary caller calls the AA.
Any idea on how to create this action?
Marcos Hernandez Tue, 02/10/2009 - 08:31
This is not possible using the native scripts. But it is possible if you create you own script using the CUE editor. You can have the system transfer the call to an arbitrary extension if the caller doesn't press any option. Very good documentation here:
Please write an email to [email protected] with specific questions about the editor. Also, please notice that customized scripts are not fully supported by TAC and that this free technical service is bona fide.
