VPN question
Feb 10th, 2009
I am trying to find out if there is a way to set a source interface for a VPN that is ran on the IOS. The router in question is a cisco 871
The config has Nat running with 5 IP's
Four of the are static entries ending in
.193 overload and assigned to the fast Ethernet port of the router
.194 assigned to a pc
.195 assigned to a pc
.196 assigned to a pc
.197 assigned to a pc
I am not sure as to what IP the router will listen for incoming VPN connections
Paolo Bevilacqua Tue, 02/10/2009 - 08:44
  • Hall of Fame,
    Founding Member
All the interface address.
themcurtis Tue, 02/10/2009 - 08:51
OK so if it is listening on all addresses with that have an effect on the client mapped to say .195?
Paolo Bevilacqua Tue, 02/10/2009 - 11:49
  • Hall of Fame,
    Founding Member
No. Interface addresses are not static nat addresses.
cdusio Wed, 02/11/2009 - 16:05
  • Bronze, 100 points or more
If you are asking what IP address the router will accept incoming connections on it's the interface that has ISAKMP enabled on it typically the outside interface.
