Command "ip load-sharing" not working on 7609,
Feb 10th, 2009
Customer is trying to use the command "ip load-sharing" in a 7609 with the version 12.2(18)SXF8 and it is not working. The same command in a 3640 with the version 12.2(27) is working.
Does someone knows if there is any restrictions from the hardware or IOS for this command on the 7609?
Yudong Wu Tue, 02/10/2009 - 09:01
  • Gold, 750 points or more
As far as I know, you can not do "per packet" load balancing (not supported) but you can do "per destination"
luizsergiosantos Tue, 02/10/2009 - 09:30
Could you tell me where I can find the information that the "per packet" load balancing is not supported.
