Giuseppe Larosa Tue, 02/10/2009 - 12:25
  • Hall of Fame,
    Founding Member
Hello Johann,
look at CoPP = control plane policing
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/copp.html
however even a single SNMP get can be disruptive if every few minutes the whole BGP table is asked to the device and the device is handling a BGP full table.
so also what SNMP gets are done and the polling rate make the difference.
Hope to help
Giuseppe
Johann Frey Tue, 02/10/2009 - 13:18
hello giuseppe,
thx for the link, but CoPP is clear for me.
my question is, is there a default rate limiter? which block my snmp request after x snmp request per sec?
Thanks - Cheers
Johann
Giuseppe Larosa Tue, 02/10/2009 - 13:40
  • Hall of Fame,
    Founding Member
Hello Johann,
I don't think there is a default rate-limiter for SNMP.
There are some built-in rate-limiters for the data plane to limit user traffic packets punted to main cpu:
The PFC3 and DFC3 provide hardware support for CoPP. CoPP works with the PFC3 rate limiters.
The PFC3 supports the built-in "special case" rate limiters that can be used when an ACL cannot classify particular scenarios, such as IP options cases, TTL and MTU failure cases, packets with errors, and multicast packets. When enabling the special-case rate limiters, the special-case rate limiters override the CoPP policy for packets matching the rate-limiter criteria.
Hope to help
Giuseppe
Johann Frey Tue, 02/10/2009 - 13:50
thx i think too!
now i open a ServiceRequest.
regards
johann
Giuseppe Larosa Tue, 02/10/2009 - 14:05
  • Hall of Fame,
    Founding Member
Hello Johann,
there isn't a default rate limiter but you can implement one.
I mean I think it is a wanted feature to let the network engineer to decide what to do in the management plane.
I think TAC will answer you in this way.
Hope to help
Giuseppe
