the amount of routes on layer 3 switch
Feb 10th, 2009
hi, gang,
Is it a good practice to put 450 static routes on a layer 3 switch? just because there are 2 ISP's to connect. I wonder how the performance is.
Overall Rating: 3 (2 ratings)
Roberto Salazar Tue, 02/10/2009 - 10:08
The performance will be fine since what is worng with this is the amount of static route you will need to manage manually. But the performance should be okay if not better since there is no routing table that needs to be updated and populated dynamically.
Giuseppe Larosa Tue, 02/10/2009 - 10:13
Hello Jon,
it can be done but I would move to eBGP connections where you receive just a few routes from one ISP and only a default route from the other one.
(other arrangaments are possible like receiving few specific routes and a default route from each provider)
This allows also for a better behaviour during faults: failure detection is far better.
Static routes if an intermediate device is on the middle become a problem
I would recommend to ask the providers about a BGP session where you put a filter and accepts only some routes (the ones you want) from each.
otherwise reliable static routing but 450 routes are difficult to manage
Hope to help
Mohamed Sobair Tue, 02/10/2009 - 11:10
The (SDM prefer routing) provides a config template for a switch database Managment for Resource allocation.
It's also rely on the Type of Switches Models & series..
xiaoliangyue Tue, 02/10/2009 - 11:21
Thanks guys. The bunch of static routes are just for routing optimization. the redundancy is achieved by 2 default routes. The difficulty to manage hundreds of static routes manually is anticipated. As long as the switch can handle such a big routing table, it's fine.
Mohamed, not sure what you're referring to, can you pls elaborate a little bit? thx.
