WS-C3560G-24TS-S Blocking or Non-Blocking ?
Answered Question
Feb 10th, 2009
Anyone knows if the WS-C3560G-24TS-S switch is a Blocking or a Non-Blocking Switch ?
Correct Answer by Roberto Salazar about 8 years 1 month ago
This platform have 32 Gbps forwarding bandwidth performance and your switch is a 24 port with maybe 2 gig uplinks? So, yes, this switch is non-blocking.
Here is the data sheet:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5528/product_data_sheet09186a00801f3d7d.html')">http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5528/product_data_sheet09186a00801f3d7d.html
Overall Rating: 5 (1 ratings)
Correct Answer
Roberto Salazar Tue, 02/10/2009 - 10:06
  • Gold, 750 points or more
Joseph W. Doherty Tue, 02/10/2009 - 12:50
The WS-C3560G-24TS-S has 28 gig ports, for true non-blocking, this would require a fabric to provide 28 * 2 (for duplex) = 56 Gbps. The specified 32 Gbps fabric is insufficient. (Also, the rated 38.7 Mpps, I believe, would not guarantee wire speed for all ports.)
If you truly want a similar small 24 copper gig port L3 switch with sufficient fabric bandwidth (and forwarding rate), consider the 3560E-24TD, its fabric provides 128 Gbps (and 65.5 Mpps).
