02-10-2009 09:53 AM - edited 07-03-2021 05:08 PM
Hello
I am trying to upgrade the IOS of my AP1200 but I am recieving this message
AP1200-BUP1-2#archive download-sw /overwrite t<A HREF="javascript:newWin('ftp://10.50.194.12//c1240-k9w7-tar.123-8.JEA2.tar')">ftp://10.50.194.12//c1240-k9w7-tar.123-8.JEA2.tar</A>
Problem solved thx
examining image...
%Error opening (Permission denied)
archive download: takes 0 seconds
Any idea how to overcome this issue ?
Ersin
02-10-2009 01:44 PM
Hi Ersin,
I'm a bit confused by your command. You have both TFTP and FTP options listed for opening the file. You only need to specify one.
Regardless, the fact that it says there is an error opening the image due to permission being denied, I imagine that this is a setting on your TFTP/FTP server. Ensure it's configured to send files, and also ensure that no password or other security is set on it.
I hope that helps!
Jeff
02-12-2009 01:49 AM
Hello
Here is the command line
Even I format the flash...
Any comment ?
AP1200-BUP1-1#
AP1200-BUP1-1#format flash:
Format operation may take a while. Continue? [confirm]
Format operation will destroy all data in "flash:". Continue? [confirm]
flashfs[1]: 0 files, 1 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 7741440
flashfs[1]: Bytes used: 1024
flashfs[1]: Bytes available: 7740416
flashfs[1]: flashfs fsck took 3 seconds.
Format of flash complete
AP1200-BUP1-1#$overwrite tftp://10.50.194.12//c1240-k9w7-tar.123-8.JEA2.tar
examining image...
%Error opening (Permission denied)archive download: takes 0 seconds
AP1200-BUP1-1#dir flash:
Directory of flash:/
02-12-2009 03:07 PM
Is this AP Joined to a WLC? I can see that you are either upgrading from LWAPP to Autonomous or you are upgrading an Automous IOS.
If the AP is Joined to a WLC, can you do the following commands on the WLC:
1. Find out what AP needs to be converted from LWAPP to Autonomous mode by entering the following command:
sh ap summary
2. Enter the following CLI command on the Wireless LAN Controller:
config ap tftp-downgrade
3. The AP will download the software and after a reboot, the AP will be on Autonomous mode.
02-13-2009 12:55 AM
Ok let me change the question
How can I manually upgrade or change the IOS of the AP1200s.Issue is there is a tar file which contains many files in it
I do not know how could I do that
Thx
Ersin
02-16-2009 06:20 PM
Is the tar file loaded on the AP? If yes, then you can do the following:
1. Go to Global mode and type the following command: tftp flash:
2. Go to priviledge mode and enter the command "arch tar /x tftp://
The AP should extract the IOS from the tar file. When done, delete the tar file, change the boot sequence and reboot the AP.
If the tar file is not in the AP, you can extract the IOS from the tar file using either WinZIP or WinRAR.
Hope this helps you.
