Advantages of Using Gatekeeper Versus Intercluster Trunks
Feb 10th, 2009
We are in the process of designing a 3-6 subscriber 6.x cluster. What are some of the advantages and disadvantages of using a gatekeeper in the cluster as compared to ICT trunks.
Chris Deren Tue, 02/10/2009 - 12:44
How many clusters are you going to have?
This is typically the big driver as you can centralize your dial plan in GK, the other pro of GK is Call Admission Control over location based CAC that can get tedious.
Chris
jcsmith96 Tue, 02/10/2009 - 13:02
we are going to have a single cluster, probably 3 subs. HUB/Spoke configuration. We want the capability to call other clusters via 7 digit dialing. I have heard that there;s a limitation using ICT call capacity and functionality. Also that we would need to configure both Clusters.
Chris Deren Tue, 02/10/2009 - 13:04
How many other clusters?
There is no limitation as all the traffic on ICT is just signaling.
RTP is between the endpoints.
Chris
Kenneth Mohammed Tue, 02/10/2009 - 13:08
Just to add a note, if you are going to have a single cluster, then you wouldn't need an ICT, as that is for communication between 2 separate clusters.
jcsmith96 Tue, 02/10/2009 - 13:44
we are looking for the the communications to other clusters, I didn't want to build ICT between them. I am interested in using if possible a Gatekeeper to do it. And was wondering if there's and advantage using a GK.
Chris Deren Tue, 02/10/2009 - 13:47
As I said the big one is going to be cetrelized dial plan and CAC.
Chris
