C3750-IPSERVICES-M question
Answered Question
Feb 10th, 2009
I have a switch with the C3750-IPSERVICES-M image on it. I thought this would allow me to do layer 3 stuff but I can't seem to enable eigrp routing. What image should I use if I need routing capabilities?
Correct Answer by Jon Marshall about 7 years 11 months ago
Roland
IPServices should support full EIGRP. What happens when you configure
3750(config)# router eigrp 1
You have enabled ip routing on the switch ? ie.
3750(config)# ip routing
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Tue, 02/10/2009 - 13:01
Roland
Jon
rshum Tue, 02/10/2009 - 13:09
Crud...I forgot to enable ip routing! Thanks Jon!
Jon Marshall Tue, 02/10/2009 - 14:48
Roland
No problem. If i had 5 points for every time i forgot this sort of thing i'd be up there with Rob :-)
Jon
