VPN Tunnel dropping
Feb 10th, 2009
1841 with Version 12.4(3h).
Continues to drop VPN tunnel Couldn't find anything specific about that in the bug reports but perhaps I'm not looking at that correctly there are many pages of errors. When I go to try to download the software I don't see it. Was this code pulled? Thanks in advance.
drolemc Mon, 02/16/2009 - 13:54
  • Silver, 250 points or more
This is a common problem associated with routing. Ensure that the PIX has a route for networks which are on the inside and not directly connected to the same subnet. Also, the inside network needs to have a route back to the PIX for the addresses in the client address pool.
