What does Synched to technology version 12.4(11)T mean?
Answered Question
Feb 10th, 2009
After typing sh ver command in the router there is a line "Synched to technology version 12.4(11)T"
what does that means???
P-R3845-NexDatos#sh ver
Cisco IOS Software, 3800 Software (C3845-SPSERVICESK9-M), Version 12.4(11)XJ, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 22-Dec-06 05:14 by prod_rel_team
I checked that the version 12.4(11)XJ has a bug CSCsk50423 , which is fixed in 12.4(11)XJ6, but I can't find it. The version available is 12.4(11)XJ4.
any suggestion?
regards
Correct Answer by Edison Ortiz about 8 years 4 months ago
The XJ track is built upon the T track with additional features for Wireless.
If you aren't using this router as a wireless router, I recommend downloading the T track instead as this bug does not affect that release.
12.4(15)T7 or T8 seems to be a solid release.
HTH,
__
Edison.
Correct Answer by Giuseppe Larosa about 8 years 4 months ago
Hello Filiberto,
it means that your image implements the features that are in 12.4(11)T.
Or you can see your image as a variation of main T technology image 12.4(11)T
so if you are not using very specific features that are only in XJ you could move to an 12.4(XX)Ty
you can use
http://www.cisco.com/go/fn')">www.cisco.com/go/fn
to compare images
you can compare last of XJ train and a 12.4T image I don't know if spservices is present in 12.4T.
Hope to help
Giuseppe
Overall Rating: 5 (2 ratings)
Correct Answer
Giuseppe Larosa Tue, 02/10/2009 - 13:51
  • Hall of Fame,
    Founding Member
Hello Filiberto,
you can use
to compare images
Hope to help
Giuseppe
Correct Answer
Edison Ortiz Tue, 02/10/2009 - 14:01
  • Hall of Fame,
    Founding Member
HTH,
__
Edison.
