Maximum number of files for trace output settings in CCM 4.1
Feb 10th, 2009
Does anyone know the maximum number of files that can be configured for trace ouput? I am not using the XML option. The only reference I can get is that the default is 250 files.
Melissa
Overall Rating: 4 (1 ratings)
Jaime Valencia Tue, 02/10/2009 - 16:52
AFAIK as many as your HDD can save, be aware that low disk space can cause performance issues so if there's no valid reason to move the parameters leave them as they are
java
if this helps, please rate
