Adding a 3rd site to existing 876 VPN routers
Feb 10th, 2009
Greetings,
I have 2 876 routers which connect trough a GRE IPsec tunnel. Also the routers by default use the ISDN port as backup in case the DSL fails.
I have 2 questions
a. If a add a 3rd site do i need to configure a separate GRE tunnel/crypto map etc or just add the details of the 3rd site to my existing config?
b. I saw that through SDM i only have the option of inserting the 'dial string' of the remote site. In this scenario i need to configure dialer map for each remote site. Will it work in 876 so that the central site dial to 2 separate destinations?
Please repply if you have any info because i am troubled if i need to keep 876 for my central site or upgrade to 1841 model, which is quite expensive.
many thanks
themis
JamesLuther Thu, 02/12/2009 - 06:28
  • Silver, 250 points or more
876 routers support 10 ipsec tunnels so you won't need to upgrade.
To configure the new site then just add it as a seperate VPN tunnel. I imagine you'll want to create a mesh? You can then setup your routing layer to reflect your chosen topology.
tnikoletos Fri, 02/20/2009 - 05:02
Greetings and thanks gor your quick reply. I feel puzzled in 2 things.
1.My current tunnel from central to site 1 is in subnet 10.0.0.X /255.255.255.252(i.e 10.0.0.1 and .2)
Can the new tunnel for site 2 be 10.0.0.3-4 or a new subnet e.g. 11.0.0.1-2 is required?
2. I run 'show startup config' and found 2 crypto isakamp policys. See below (i have removed the real ip addresses with x1, x2,x3). How can i check which one is currently used?
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp policy 2
encr 3des
group 2
crypto isakmp key xxxxx address x1
crypto isakmp key xxxxx address x2
crypto isakmp key xxxxx address x3
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel to x2
set peer x2
set transform-set ESP-3DES-SHA
match address 100
interface Tunnel1
ip address 10.0.0.1 255.255.255.252
qos pre-classify
keepalive 1 3
tunnel source Dialer1
tunnel destination x2
interface Dialer1
description $FW_OUTSIDE$
ip address xxxxxx 255.255.255.0
ip access-group 107 in
ip nat outside
ip inspect SDM_MEDIUM out
ip virtual-reassembly
encapsulation ppp
dialer pool 2
dialer-group 2
no cdp enable
ppp authentication xxxx
ppp chap hostname xxxxx
ppp chap password 7 xxxxx
ppp pap sent-username xxxxxx password 7 xxxx
I need to do this setup on an already configured router and my experience is basic so please be as descriptive as possible.
Again, thanks for your time :)
regards,
themis
