Ciscoworks Alerts (delay)
Feb 10th, 2009
We have an issue here in Ciscoworks where in most of the alerts we received from Ciscoworks are delayed. Like last January 22 issues. One of our devices is down and there should be an alert on the same day of incident but we only received the alert last January 24. This is not the first we
encounter this kind of issue. Please advice on why the alerts are delayed and
how to avoid this.
Joe Clarke Wed, 02/11/2009 - 10:45
In what application are you receiving these alerts? What version of LMS are you using? What does one of these alerts look like?
ronmarcojr Wed, 02/11/2009 - 17:07
The version of LMS is 2.6.
Below is the sample of email notification that we have received.
Sent: Saturday, January 24, 2009 5:32 AM
Subject: 00026QB ; pcgsw1011 ; Thu 22-Jan-2009 21:20:48 CST ; Critical ;
OperationallyDown ; Active
EVENT ID = 00026QB
ALERT ID = 000064L
TIME = Thu 22-Jan-2009 21:20:48 CST
STATUS = Active
SEVERITY = Critical
MANAGED OBJECT = pcgsw1011
MANAGED OBJECT TYPE = Switches and Hubs
EVENT DESCRIPTION = OperationallyDown::Component=PORT-pcgsw1011/10101 [Gi1/0/1] [*** Connection To PCGRT9011 ***];Type=ETHERNETCSMACD;OperStatus=DOWN;InterfaceCode=CODEUNKNOWN;DuplexMode=FULLDUPLEX;AdminStatus=UP;LastChangedAt=22-Jan-2009 9:20:48 PM;IsFlapping=false;Max
Joe Clarke Wed, 02/11/2009 - 18:29
So is the problem that email notifications are being delayed, or that these events are not showing up in DFM's Alerts and Activities Display? From this particular event, it appears that it should be showing up in AAD around 1/22/09 21:20.
ronmarcojr Wed, 02/11/2009 - 18:43
Most of the alerts from Alerts and activities feature are delayed, not only in email notification.
Any suggestions?
Joe Clarke Wed, 02/11/2009 - 18:57
Enable Event Promulgation Module and Adapter debugging under DFM > Configuration > Other Configurations > Logging. When the problem occurs again, post the logs under NMSROOT\log\dfmLogs\EPM and epa along with a sample delayed event.
ronmarcojr Wed, 02/11/2009 - 19:05
If we enable the debugging on ciscoworks, this will not incur high utilization on the server? Our syslog file occupies large disk space because the logrot is not working.. Please advise..
Thank you very much for your assistance..
Joe Clarke Wed, 02/11/2009 - 19:12
It depends on how active DFM is (i.e. the number of devices and number of events) as to the CPU impact this debugging will incur. Typically, the impact will be minimal.
ronmarcojr Wed, 02/11/2009 - 19:20
Thank you very much!
I'll post the logs and the sample delayed events when the problem reoccurs..
