OSPF Implementation
Answered Question
Feb 10th, 2009
Hi All,
I have my company network consists of 4 sites. Each one connected to other by Mugs.(Serail - 45 Mbps). In each site the main router in connected to other router which in connected to Firewall & then L3 Switch then L2 Switch & then Servers & Users.
Between 2 sites there is VPN Connection also. I have implement OSPF on this VPN network. Now there is static route.
So how can I implement OSPF?
Correct Answer by Istvan_Rabai about 8 years 2 weeks ago
Hi Chandrakant,
You may need to configure GRE over IPSec Tunnel instead of the site-to-site VPN connection.
GRE over IPsec will forward the multicast packets that OSPF needs to build up neighbor relationship and send - receive updates.
Here's a link that can be useful for you describing how to configure GRE over IPSec with OSPF:
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a00800a43f6.shtml
Cheers:
Istvan
Overall Rating: 5 (1 ratings)
Correct Answer
Istvan_Rabai Tue, 02/10/2009 - 22:43
Hi Chandrakant,
Cheers:
Istvan
Istvan_Rabai Wed, 02/11/2009 - 04:45
Hi Chandrakant,
You're welcome of course.
Please rate my post if it was helpful.
Thank you:
Istvan
