iptuser55 Wed, 02/11/2009 - 02:09
  • Silver, 250 points or more
There are lots of docs. out there however configure CUCM as QSIG ISO but the more important thing is on the Nortel side. in LD 16? Route Block change the setting from ESN? to STD i.e you do not want the Nortel to send the NCOS value as part of the digits otherhwise CUCM will see it as a dial number and fail the call. Do a q931 debug and up will see in the normal set up something like 0051234 - 005 the NCOS value and 1234- DN once you set it to STD only the DN is seen, Also set the CUCM as NONCRC4- help it helps
Rob Huffman Wed, 02/11/2009 - 05:42
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Siva,
Just to add a note to the good tips from IPT (+5 IPT - I wish I had your name :)
The concepts are laid out pretty well in this doc;
Nortel Meridian 1 Release 25.40B using E1 QSIG to Cisco Unified CallManager 4.1
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/pbx/interop/notes/431470nt.pdf
Hope this helps!
Rob
iptuser55 Wed, 02/11/2009 - 08:21
The STD part is in LD 16 RDB under SIGO-make it STD
