ip route command
Feb 10th, 2009
Hi Friends,
Just would like to know what is the diffrence between the command "ip route 0.0.0.0 0.0.0.0" and "ip route 0.0.0.0 255.255.255.255" ??
Thanks in advance.
Manoj
massimiliano.se... Wed, 02/11/2009 - 00:34
  • Silver, 250 points or more
if you use ip route 0.0.0.0 0.0.0.0 you insert in the routing table a default route.
instead if you use 0.0.0.0 255.255.255.255 you insert in the routing table only the route toward host 0.0.0.0
I hope this helps.
Best regards.
Massimiliano.
Manoj Wadhwa Wed, 02/11/2009 - 00:45
Hi Massimiliano,
Thanks for the reply. Since there is no host with ip 0.0.0.0, does it mean that this command ip route 0.0.0.0 255.255.255.255 does not have any impact ?
Manoj
Richard Burts Wed, 02/11/2009 - 04:44
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Manoj
Since there should not be a host with address 0.0.0.0 then the route to 0.0.0.0 255.255.255.255 would never be used.
Rick
