02-11-2009 12:16 AM
When I run DMA on my publisher server, I get the following warning:
* The following section displays warnings found during
* directories export.
* Date/Time : 02-09-09/02:14:42 PM
Script DirExport.pl v1.0(28) executed at 02/09/2009 14:14:44
02/09/2009 14:20:03
Warning: Numplan (NULL) for User afco is invalid. Ignoring the user
Condition: Primary Extension for this user is invalid. It does not exist in the database
Solution: Please ensure that the user is associated with a valid primary
extension/numplan
02/09/2009 14:20:03
Warning: Numplan (NULL) for User cthaba is invalid. Ignoring the user
extension/numplan
02/09/2009 14:20:03
Warning: Numplan (NULL) for User lsomers is invalid. Ignoring the user
extension/numplan
02/09/2009 14:20:03
Warning: Numplan (NULL) for User guest is invalid. Ignoring the user
extension/numplan
02/09/2009 14:20:03
Warning: Numplan (NULL) for User mnadar is invalid. Ignoring the user
extension/numplan
02/09/2009 14:20:03
Warning: Numplan (NULL) for User lmccarthy is invalid. Ignoring the user
extension/numplan
02/09/2009 14:20:03
Warning: Numplan (NULL) for User auditor12 is invalid. Ignoring the user
extension/numplan
02/09/2009 14:20:03
Warning: Numplan (NULL) for User mjacklin is invalid. Ignoring the user
extension/numplan
02-18-2009 07:39 AM
Associate the user with a valid primary extension/numplan.
This would stop displaying the warning message.
02-23-2009 11:28 AM
I recieved the sam error messages, i opened a case w Cisco and here's what they said. From what i can tell this is old user info..
After some research I found that this issue is a Bug CSCsq78533
<http://cdets.cisco.com/apps/goto?identifier=CSCsq78533>
Unfortunately it's not fixed yet, then I found similar cases as yours and this is what developers state.
"These are not errors just warnings so even with this warnings if you proceed your upgrade would succeed. The only problem is that you won't be able to see the multiple device association for those users reporting error".
Example. User thompt maybe had a device with the MAC 0006d79c6 associated in the past, and now It's not found into the database, so It won't be added.
