PIX or router issue
Feb 11th, 2009
Following is a lab topology:
I cannot ping from interent(LAB) router to the inside interface of pix as well as lan.
ALso cannot ping outside interface of Pix from lan but can ping the system on internet(LAB) .
Can anyone help .
Thanks in advance.
system A ------>switch------->LAN Router---->firewall--->Internet Router----->Switch----->System B
System A IP:10.1.2.5/24
gateway: 10.1.2.1
System B ip:172.16.10.5/24
LAN Router Configuration:
interface Ethernet0/0
ip address 10.1.2.1 255.255.255.0
half-duplex
interface Ethernet0/1
ip address 10.1.1.2 255.255.255.0
half-duplex
ip route 0.0.0.0 0.0.0.0 10.1.1.1
PIX configuration:
interface Ethernet0
nameif outside
security-level 0
ip address 10.165.200.226 255.255.255.224
interface Ethernet1
nameif inside
security-level 100
ip address 10.1.1.1 255.255.255.0
access-list 100 extended permit icmp any any echo
access-list 100 extended permit icmp any any echo-reply
access-list 100 extended permit icmp any any time-exceeded
access-list 100 extended permit icmp any any unreachable
access-list 100 extended permit tcp any any eq smtp
global (outside) 1 10.165.200.227-10.165.200.254 netmask 255.255.255.224
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) 10.165.200.228 10.1.2.5 netmask 255.255.255.255
access-group 100 in interface outside
route outside 0.0.0.0 0.0.0.0 10.165.200.225 1
route inside 10.1.2.0 255.255.255.0 10.1.1.2 1
Internet Router:
interface Ethernet0
ip address 10.165.200.225 255.255.255.224
half-duplex
interface FastEthernet0
ip address 172.16.10.1 255.255.255.0
speed auto
seekhpar121 Wed, 02/11/2009 - 20:13
Thanks for your response.
FRom system A:
1)CAN ping System B.
2)CANNOT ping outside interface of pix
3)CAN ping ETH0 of internet router connected to outisde interface of pix.
From PIX:
Can ping Internet router as well as System B:
From Internet Router:
Cannot ping Inisde interface of PIX:
From System B:
When ping inside interface of pix:Result is
Reply from 172.16.10.1:destination host unreachable
Waiting for more replies.
This is normal behaviour.
From the outside of the pix you will not be able to ping the inside IP. From the inside of the pix you will not be able to ping the outside IP = all normal for the PIX.
For your network connectivity tests that prove the network from end to end will be:-
system A ping switch = OK
system A ping LAN Router = OK
system A ping firewall inside = OK
system A ping internet router = OK
The above proves the system A side 100%
system B ping switch = OK
system B ping internet router = OK
system B ping firewall outside = OK
system B ping LAN router = OK
The above proves the system B side 100%
system B ping system A = OK
That means you have 100% end to end connectivity.
HTH>
seekhpar121 Thu, 02/12/2009 - 20:09
system B cannot ping LAN Router,
Response is
Reply from 172.16.10.1(internet Router ip),destination host unreachable.
Also System B cannot ping System A.
PIX os is v8.0(3)
seekhpar121 Fri, 02/13/2009 - 06:21
Following is the internet router configuration.
Internet Router:
interface Ethernet0
half-duplex
speed auto
seekhpar121 Fri, 02/13/2009 - 19:40
AT PIX for allowing icmp as well as routes and static natting of system A
