Why we are giving the command no spanning-tree optimize bpdu transmission?
Feb 11th, 2009
What is the full impact of following command in the particular switch.
spanning-tree portfast bpduguard default
spanning-tree portfast bpdufilter default
vlan internal allocation policy ascending
Aneesh
Overall Rating: 4 (1 ratings)
Giuseppe Larosa Wed, 02/11/2009 - 02:26
Hello Aneesh,
I strongly recommend to not use BPDU fiter command that disables sending of BPDUs out all spanning portfast ports.
the right command for protection is the first
So I would do
no spanning-tree portfast bpdufilter default
BPDU filter is there for L2 SP that wants to not participate in customer STP topology not to be used in an enterprise access layer.
all the other commands are actually defaults:
allows for MAC address reduction
STP priority in vlan X = base_pri + X
where base_pri in in multiple of 4096
So we are not giving these commands they are three default settings that are shown in configuration
the no spanning-tree optimize bpdu transmission let the BPDUs to flow through the switch without attempting to optimize them.
You should be fine with these settings execpt thee filter command that I would remove.
Hope to help
Giuseppe
