Hello, I was wondering if anyone knew a SQL query to obtain the time stamp the user last received a voicemail?And or how about the last time the user accessed their VM box via the TUI
The content you are looking for has been archived. View related content below.
HI There, hoping someone has done this before and can help me out, as i am struggling to find any official Cisco documentation to help. We're having to change all of the DNS server IP addresses in our CUCM cluster, I have the process for CUCM and UC...
Hope you're fine. I'm trying make do a CUCM Backup , but I can´t start, I click : Backup> Backup Device and it gets stuck i found TOMCAT-ECDSA expire and regenrate it but still same isseue als DRF restart
Hi all, I'm installing a new cucm 12.5.x and I'm stuck in the DNS lookup install I did all the checks and from different servers and dns are working as expected. Thanks.
We have a situation in which some of our database are switching off and on of VPN to join customer VPN connections during the day and while on calls. The call drops during the switch. One idea is to have jabber register Only through MRA and not on pr...
Customer has a gateway running MGCP. Gateway has an FXO card in it. One of the ports has started acting strangely. Inbound callers to the number just hear ringing. The phone will ring 3 times and then simply stop. No forwarding set up on the ph...
Hi Everyone, I hope everyone in the community is doing well.I have 4 SIP connections terminated to the vCUBE (PSTN, Webex, Teams, and on-prem CUCM). I am using DPG on each incoming dial-peer to route the call to the outgoing dial-peers. However, on t...
Hi, Newbie again here, Why would Prime licensing manager suddenly be in demo mode after 2 years of use? All licenses, seem to be gone. Thanks, Sam
Hello dears, I hope you are doing well I would like to know if someone has had any experience in an integration between CUCM 12.5(1)SU8a and CUP 12.5(1)SU8. There is a CUCM cluster which we want to upgrade 12.5(1)SU8a. There is too a CUP server emb...
Hello everybody. Customer has a UNITY server unable to save voice mails because it reached 95% use on logging partition. Unity version 12.5.1.11900-57, only one Publisher. On RTMT I modified high/low watermark level to 40/30, and I restarted " CIsco ...
Hi there,I have a scenario where some coworkers are receiving calls in a pickup group. They also have mobility enabled and a Remote Destination configured to ring every time their phone does. In this case the Remote Destination is Microsoft Teams Cli...
So....i have a SME and a leaf cluster.CXN is connected to the SME. Calls from external ITSP-CUBE-SME-User(forwarded to VM) on LEAF-SME-CXNReach voice mail correctly Calls from another client:JABBER(LEAF)-User(forwarded to VM) on LEAF-SME-CXNfails wit...
I need to change the IP on an MGCP VG 310 but can't find documentation that tells whether any changes need to happen on the Gateway section in UCM. Could someone point me to the documentation on this or let me know about any required changes in CUCM?...
Hello, We're deleting users using the csp_subscriberdelete stored procedure sent via soap to CiscoUnityDb Given a user that has been imported from: Import Users > select LDAP server > list users, select and click import If I delete it from Unity, the...
Hello, my customer wants that outgoing calls from CUBE are identified with different numbers from a pool. The incoming call comes into the CUBE with always the same identification (calling number), so I can't map with translations rules to manipulate...
Subject | Author | Posted |
03-21-2024 09:17 AM | ||
03-14-2024 11:09 AM | ||
02-26-2024 12:21 AM | ||
02-19-2024 05:04 AM | ||
02-19-2024 04:36 AM |
User | Count |
5 | |
5 | |
3 | |
2 | |
1 |
