monitor of flooded packets
Feb 11th, 2009
one switch, 10 acces ports in vlan 10, on P1 a pc with sniffer, on P2 a pc with "source packets", i monitor in tx on the ports P3-P10, to the P20 in witch is connected another sniffer.
A packet entering the P2 with a unknown mac address is flooded on all the ports. I see it on the P1 sniffer, and i will see once on the SPAN sniffer of 8 times?
Giuseppe Larosa Wed, 02/11/2009 - 02:53
  • Hall of Fame,
    Founding Member
Hello Ciprian,
yes replications are possible SPAN for efficiency reasons doesn't track the frames.
Are you using as SPAN source vlan 10 or the 8 physical ports ?
Hope to help
Giuseppe
Giuseppe Larosa Wed, 02/11/2009 - 09:14
  • Hall of Fame,
    Founding Member
Hello Ciprian,
using Vlan 10 as source might be a way to see less copies of same unknown unicast frame but I'm not sure.
Hope to help
Giuseppe
