Can't upgrade from LMS 3.0.1 to LMS 3.1 : backup fails
Feb 11th, 2009
I want to upgrade LMS but backup fails at the beginning of the upgrade with this message in the backup.log file :
Starting database engine dfmFhEng
ERROR(951): Fatal error: Database engine 'dfmFhEng' could not be started on database 'dfmFhDb' in Bulk mode..
Backup failed: 2009/02/11 11:43:07
Who can help me?
Joe Clarke Wed, 02/11/2009 - 09:03
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Either your DFM fault history database is corrupt, or the transaction log is corrupt. With Daemon Manager shut down, post the list of contents of NMSROOT/databases/dfmFh as well as the OS on which LMS is running.
korrigan29 Thu, 02/19/2009 - 06:34
My OS is Windows 2003 Server Enterprise Edition (Upgrade SP2)
The content of dfmFh is :
2 files : dfmFh.log (8KB)and dfmFh.db (140 980KB) and a directory "orig" with 3 files :dfmFh.dborig (796KB) odbc.tmpl (1KB)and odbc.tmplorig (1KB).
If It's possible to erase the Dfm database I can do it (But How?).
Joe Clarke Thu, 02/19/2009 - 14:31
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Do this, shutdown the Daemon Manager service. Delete the dfmFh.log. Run the following command:
NMSROOT\objects\win32\dbsrv9 -f NMSROOT\databases\dfmFh\dfmFh.db
Then you should be able to perform your backup.
